Yuneec Typhoon H Gimbal Bushing Reattachment
  1. Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: step 1, image 1 of 2 Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: step 1, image 2 of 2
    • In order to repair the camera and camera gimbal, remove the camera configuration from the body of the drone.
    • Pull up on the tab connected to the camera configuration and slide the entire apparatus off.
  2. Yuneec Typhoon H Gimbal Bushing Reattachment: step 2, image 1 of 3 Yuneec Typhoon H Gimbal Bushing Reattachment: step 2, image 2 of 3 Yuneec Typhoon H Gimbal Bushing Reattachment: step 2, image 3 of 3
    • Put the gimbal bushings (the rubber balls) back into the plastic alignment mounts.
    • The circle that is separated from the main body of the bushing should then be inserted into the hole.
    • When pushing these bushings back into place, it is smart to use a skinny tool or toothpick.
To reassemble your device, simply slide the camera mount back onto the bottom of the drone.
2 other people completed this guide.
Jake Breul
127 Reputation
1 Guide authored
Cal Poly, Team S22-G3, Maness Spring 2018 Member of Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 Members
5 Guides authored
3 Comments
Camera not getting power after crash.
Don - Reply
Crashed drone and camera not getting power anymore. Nothing appears to be broken.
Don - Reply
Did steps. Bushings ok. Camera still won't communicate.
vickiesamus - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,705
