Yuneec Typhoon H LED Board Replacement
  1. Yuneec Typhoon H LED Board Replacement, LED Board: step 1, image 1 of 1
    • This guide begins with the propeller already removed.
  2. Yuneec Typhoon H LED Board Replacement: step 2, image 1 of 2 Yuneec Typhoon H LED Board Replacement: step 2, image 2 of 2
    • Turn the drone upside down to have easy access to the prop arm.
    • Twist out the prop motor clockwise.
  3. Yuneec Typhoon H LED Board Replacement: step 3, image 1 of 1
    • Unscrew two 4.9mm screws on the board using a Phillips #000 screwdriver.
  4. Yuneec Typhoon H LED Board Replacement: step 4, image 1 of 2 Yuneec Typhoon H LED Board Replacement: step 4, image 2 of 2
    • Hold the LED board in one hand and pinch the plug at the connection to the board with the other hand.
    • Pull the plug out from the connection piece.
Claire Luce
371 Reputation
2 Guides authored
Cal Poly, Team S22-G3, Maness Spring 2018 Member of Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 500
