Yuneec Typhoon H Landing Gear Replacement
  1. Yuneec Typhoon H Landing Gear  Replacement, Landing Gear: step 1, image 1 of 2 Yuneec Typhoon H Landing Gear  Replacement, Landing Gear: step 1, image 2 of 2
    • Lift all drone arms up so you can access the landing gear easily.
  2. Yuneec Typhoon H Landing Gear  Replacement: step 2, image 1 of 3 Yuneec Typhoon H Landing Gear  Replacement: step 2, image 2 of 3 Yuneec Typhoon H Landing Gear  Replacement: step 2, image 3 of 3
    • Unscrew the 16.9 mm screw at the top of the landing leg with a Phillips #00 screwdriver.
    • Make sure the screw head is not stripped in the process.
    • If stripped, the whole leg, including the internal sensors, will need to be replaced.
  3. Yuneec Typhoon H Landing Gear  Replacement: step 3, image 1 of 1
    • Pull the landing leg out slowly and remove it from the device.
Your Yuneec Typhoon H should now be ready to fly safely again.
Shasta Banchio
130 Reputation
1 Guide authored
Cal Poly, Team S22-G3, Maness Spring 2018 Member of Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 992
