Yuneec Typhoon H Plus Landing Gear Replacement
  1. Yuneec Typhoon H Plus Landing Gear Replacement, C23 Camera: step 1, image 1 of 2 Yuneec Typhoon H Plus Landing Gear Replacement, C23 Camera: step 1, image 2 of 2
    • Flip the drone over and press the button to remove the camera.
  2. Yuneec Typhoon H Plus Landing Gear Replacement: step 2, image 1 of 2 Yuneec Typhoon H Plus Landing Gear Replacement: step 2, image 2 of 2
    • Slide the camera toward the front of the drone and remove it.
  3. Yuneec Typhoon H Plus Landing Gear Replacement, Landing Gear: step 3, image 1 of 2 Yuneec Typhoon H Plus Landing Gear Replacement, Landing Gear: step 3, image 2 of 2
    • Remove two 11 mm screws from the base of the landing gear with a 2mm hex bit.
  4. Yuneec Typhoon H Plus Landing Gear Replacement: step 4, image 1 of 1
    • Remove the landing gear stopper, allowing the wire to slide out of it.
  5. Yuneec Typhoon H Plus Landing Gear Replacement: step 5, image 1 of 1
    • Lift the landing gear straight up and remove it from the drone.
Brice Black
557 Reputation
4 Guides authored
Cal Poly, Team S2-G1, White Winter 2020 Member of Cal Poly, Team S2-G1, White Winter 2020
CPSU-WHITE-W20S2G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 734
