Yuneec Typhoon H Plus Propeller Replacement
  1. Yuneec Typhoon H Plus Propeller Replacement, Propeller: step 1, image 1 of 1
    • Locate the broken propeller and figure out if it is a A-propeller or B-propeller.
    • An A-propeller will have a black button in the center and an A imprinted on the propeller.
    • A B-propeller will have a white button and a B imprinted on the propeller.
    • Though the A and B propellers are different the steps to replace one are the same.
  2. Yuneec Typhoon H Plus Propeller Replacement: step 2, image 1 of 1
    • Press down on the button firmly.
  3. Yuneec Typhoon H Plus Propeller Replacement: step 3, image 1 of 2 Yuneec Typhoon H Plus Propeller Replacement: step 3, image 2 of 2
    • Hold the base of the propeller with your pointer finger.
    • Make sure to continue to hold the button down. Rotate the propeller counter-clockwise, holding the base steady.
    • Lift the propeller off the drone.
Brice Black
557 Reputation
4 Guides authored
Cal Poly, Team S2-G1, White Winter 2020 Member of Cal Poly, Team S2-G1, White Winter 2020
CPSU-WHITE-W20S2G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 217
