Yuneec Typhoon H Spring Clip Replacement
  1. Yuneec Typhoon H Spring Clip  Replacement, Spring Clip: step 1, image 1 of 3 Yuneec Typhoon H Spring Clip  Replacement, Spring Clip: step 1, image 2 of 3 Yuneec Typhoon H Spring Clip  Replacement, Spring Clip: step 1, image 3 of 3
    • Using a JIS #00 screwdriver, unscrew the 3mm oval screw.
    • The oval screw is hard to remove once fully unscrewed, to remove the screw flip the drone upside down to have the screw fall out.
  2. Yuneec Typhoon H Spring Clip  Replacement: step 2, image 1 of 2 Yuneec Typhoon H Spring Clip  Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • For this step the arm must be bent.
    • Remove the broken arm clip by pinching the metal top and then pull it out with an upward force.
    • The Blunt Nose Tweezers may be helpful in removing the arm clip.
2 other people completed this guide.
Claire Luce
371 Reputation
2 Guides authored
Cal Poly, Team S22-G3, Maness Spring 2018 Member of Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 Members
5 Guides authored
One Comment
what function does the little screw have?
Ruud - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,126
