ZTE Avail 2 Battery Replacement
  1. ZTE Avail 2 Battery Replacement, Battery: step 1, image 1 of 3 ZTE Avail 2 Battery Replacement, Battery: step 1, image 2 of 3 ZTE Avail 2 Battery Replacement, Battery: step 1, image 3 of 3
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. ZTE Avail 2 Battery Replacement: step 2, image 1 of 2 ZTE Avail 2 Battery Replacement: step 2, image 2 of 2
    • Remove the battery by the notch in the back plate.
    • Once you have removed the battery replace it with the new one.
    • Carefully insert the new battery with the connectors aligned correctly.
    • Gently push down on the battery until it clicks into place.
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 667
