ZTE Blade Z Max Screen/Digitizer Replacement
  1. ZTE Blade Z Max Screen/Digitizer Replacement, SIM Card: step 1, image 1 of 3 ZTE Blade Z Max Screen/Digitizer Replacement, SIM Card: step 1, image 2 of 3 ZTE Blade Z Max Screen/Digitizer Replacement, SIM Card: step 1, image 3 of 3
    • Turn the device on it side with the buttons away from you.
    • Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
    • Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
  2. ZTE Blade Z Max Screen/Digitizer Replacement: step 2, image 1 of 3 ZTE Blade Z Max Screen/Digitizer Replacement: step 2, image 2 of 3 ZTE Blade Z Max Screen/Digitizer Replacement: step 2, image 3 of 3
    • Pull the tray out with your fingers .
    • Remove the SIM card.
  3. ZTE Blade Z Max Screen/Digitizer Replacement, Fingerprint Sensor: step 3, image 1 of 1
    • Remove the one T2 screw from the side of the phone near where the SIM card tray was.
  4. ZTE Blade Z Max Screen/Digitizer Replacement: step 4, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 4, image 2 of 2
    • Insert a plastic opening tool into the space where the SIM card tray used to be.
    • Gently pry the back away form the phone frame until you hear and audible click of the back separating.
  5. ZTE Blade Z Max Screen/Digitizer Replacement: step 5, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 5, image 2 of 2
    • Insert the plastic opening tool into the space you created between the phone back and frame.
    • Slide the plastic opening tool along the outside of the phone, underneath the back, to separate the rest of the clips holding the back onto the frame.
  6. ZTE Blade Z Max Screen/Digitizer Replacement: step 6, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 6, image 2 of 2
    • Rotate the back over to the side, being careful not to damage the fingerprint sensor ribbon cable.
    • Use a plastic opening tool to separate the fingerprint sensor from the back of the phone.
    • On reassembly, add a piece of simple scotch tape to hold the fingerprint sensor to the phone back.
    • Set the phone back aside.
  7. ZTE Blade Z Max Screen/Digitizer Replacement: step 7, image 1 of 1
    • Remove the 6 silver 2.9mm screws from the back of the phone with a JIS #000 bit.
    • Remove the 11 black 3.5mm screws with the same JIS #000 bit.
  8. ZTE Blade Z Max Screen/Digitizer Replacement: step 8, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 8, image 2 of 2
    • Turn the phone over, with the screen up.
    • Insert the opening tool between the screen and the silver trim that surrounds it.
    • Run the plastic opening tool around the circumference of the phone to separate the clips of that hold the trim to the frame.
  9. ZTE Blade Z Max Screen/Digitizer Replacement: step 9, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 9, image 2 of 2
    • Turn the phone back over, with the screen down.
    • Lift the trim piece off of the phone and set aside.
  10. ZTE Blade Z Max Screen/Digitizer Replacement: step 10, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 10, image 2 of 2
    • Using a plastic opening tool, separate the fingerprint ribbon connector from the motherboard.
  11. ZTE Blade Z Max Screen/Digitizer Replacement, Battery: step 11, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement, Battery: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to carefully pull up on the tape securing the connector.
    • This will undo the connector as well.
  12. ZTE Blade Z Max Screen/Digitizer Replacement: step 12, image 1 of 3 ZTE Blade Z Max Screen/Digitizer Replacement: step 12, image 2 of 3 ZTE Blade Z Max Screen/Digitizer Replacement: step 12, image 3 of 3
    • Be careful to not damage the battery during this step. If it appears you are using too much force to separate the battery from the frame, you may need to heat the phone to soften the adhesive holding the battery to the phone.
    • Starting at the bottom left corner of the battery, use the wide end of the spudger as a wedge to get underneath the battery.
    • Insert a plastic opening tool into the space created by the spudger and CAREFULLY begin to pry around the edge of the battery.
    • Once the battery is separated for enough from the phone, use your hands to fully remove the battery, using the wide end of the spudger to scrape off adhesive where necessary.
  13. ZTE Blade Z Max Screen/Digitizer Replacement, Side Mounted Buttons: step 13, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement, Side Mounted Buttons: step 13, image 2 of 2
    Buy
    • Using a set of tweezers, pull off the small piece of tape on top of the ribbon cable connector on the left side of the motherboard.
  14. ZTE Blade Z Max Screen/Digitizer Replacement: step 14, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 14, image 2 of 2
    • Use a plastic opening tool or spudger to scrape the glue away from the ribbon cable.
  15. ZTE Blade Z Max Screen/Digitizer Replacement: step 15, image 1 of 3 ZTE Blade Z Max Screen/Digitizer Replacement: step 15, image 2 of 3 ZTE Blade Z Max Screen/Digitizer Replacement: step 15, image 3 of 3
    • Using a plastic opening tool or spudger, open the zip connection by prying up on the right (black) side of the connector.
    • Using the tweezers, carefully pull the the ribbon cable out of the connector.
  16. ZTE Blade Z Max Screen/Digitizer Replacement: step 16, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 16, image 2 of 2
    • The button ribbon cable is very fragile, especially near the down volume button. If you intend on reinstalling this piece later, be careful not to rip it.
    • Using a plastic opening tool or tweezers, pry the edge of the button strip away from the phone.
    • Once all of the buttons are free, the whole assembly should simply lift out.
    • Glue may be required to hold the new buttons to the phone.
  17. ZTE Blade Z Max Screen/Digitizer Replacement, Charging Port Card: step 17, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement, Charging Port Card: step 17, image 2 of 2
    • Use a spudger to pry up the the antenna connector on the top right of the charging port card.
  18. ZTE Blade Z Max Screen/Digitizer Replacement: step 18, image 1 of 1
    • Use a plastic opening tool to pry up and remove the primary connector for the card, located on the top left of the card.
  19. ZTE Blade Z Max Screen/Digitizer Replacement: step 19, image 1 of 3 ZTE Blade Z Max Screen/Digitizer Replacement: step 19, image 2 of 3 ZTE Blade Z Max Screen/Digitizer Replacement: step 19, image 3 of 3
    • Use a plastic opening tool, spudger, or opening pick to separate the bottom edge of the card away from the phone.
    • Lift the bottom edge of the card high enough that you can grab it with your fingers, and simply remove it from the phone.
  20. ZTE Blade Z Max Screen/Digitizer Replacement, Screen/Digitizer: step 20, image 1 of 3 ZTE Blade Z Max Screen/Digitizer Replacement, Screen/Digitizer: step 20, image 2 of 3 ZTE Blade Z Max Screen/Digitizer Replacement, Screen/Digitizer: step 20, image 3 of 3
    • Use a plastic opening tool to lift the lower connection cable, which is held on by adhesive, off of the phone frame.
  21. ZTE Blade Z Max Screen/Digitizer Replacement: step 21, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 21, image 2 of 2
    • Use the plastic opening tool to separate the connector ribbon from the bottom center of the phone.
  22. ZTE Blade Z Max Screen/Digitizer Replacement: step 22, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 22, image 2 of 2
    • Use a plastic opening tool to separate the first motherboard connector from the bottom left of the motherboard.
  23. ZTE Blade Z Max Screen/Digitizer Replacement: step 23, image 1 of 3 ZTE Blade Z Max Screen/Digitizer Replacement: step 23, image 2 of 3 ZTE Blade Z Max Screen/Digitizer Replacement: step 23, image 3 of 3
    • Starting from the connector you just removed, carefully peel the ribbon cable away from the phone.
    • You may need to use an adhesive to reattach this cable during reassembly.
    • Set the ribbon cable aside.
  24. ZTE Blade Z Max Screen/Digitizer Replacement: step 24, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 24, image 2 of 2
    • Use a plastic opening tool to disconnect the second motherboard connector from the bottom right of the motherboard.
  25. ZTE Blade Z Max Screen/Digitizer Replacement: step 25, image 1 of 3 ZTE Blade Z Max Screen/Digitizer Replacement: step 25, image 2 of 3 ZTE Blade Z Max Screen/Digitizer Replacement: step 25, image 3 of 3
    • Use a plastic opening tool to disconnect the upper antenna connector.
    • Remove the antenna from the phone and set aside.
  26. ZTE Blade Z Max Screen/Digitizer Replacement: step 26, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 26, image 2 of 2
    • Use the plastic opening tool to remove the charging port card of the phone.
  27. ZTE Blade Z Max Screen/Digitizer Replacement: step 27, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 27, image 2 of 2
    • Use a plastic opening tool to disconnect the digitizer ribbon connector located on the opposite side of the antenna connection and near the side button connector.
  28. ZTE Blade Z Max Screen/Digitizer Replacement: step 28, image 1 of 2 ZTE Blade Z Max Screen/Digitizer Replacement: step 28, image 2 of 2
    • Carefully lift the motherboard out of the frame.
  29. ZTE Blade Z Max Screen/Digitizer Replacement: step 29, image 1 of 1
    • Use a plastic opening tool or spudger to remove the earpiece from the frame, located near the top of the phone.
    • All of the components you will now have removed will go into a different frame which contains the new screen.
12 other people completed this guide.
2 Comments
Thanks! This helped loads with my repair.
Isaac Pettis - Reply
Thanks for the tutorial. It helped a ton and was easy to follow. I would add the screen replacement from the frame portion of the assembly.
Americo Garcia Jr - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 36
All Time: 4,827
