ZTE Lever Volume Buttons Replacement
  1. ZTE Lever Volume Buttons Replacement, Battery: step 1, image 1 of 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Volume Buttons Replacement: step 2, image 1 of 2 ZTE Lever Volume Buttons Replacement: step 2, image 2 of 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Volume Buttons Replacement: step 3, image 1 of 2 ZTE Lever Volume Buttons Replacement: step 3, image 2 of 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Volume Buttons Replacement: step 4, image 1 of 2 ZTE Lever Volume Buttons Replacement: step 4, image 2 of 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Volume Buttons Replacement: step 5, image 1 of 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Volume Buttons Replacement, Volume Buttons: step 6, image 1 of 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Volume Buttons Replacement: step 7, image 1 of 3 ZTE Lever Volume Buttons Replacement: step 7, image 2 of 3 ZTE Lever Volume Buttons Replacement: step 7, image 3 of 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Volume Buttons Replacement: step 8, image 1 of 2 ZTE Lever Volume Buttons Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Volume Buttons Replacement: step 9, image 1 of 2 ZTE Lever Volume Buttons Replacement: step 9, image 2 of 2
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
Michael Gonzalez
501 Reputation
4 Guides authored
USF Tampa, Team S5-G2, Passmore Spring 2018 Member of USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 193
