ZTE Telstra T95 Battery Replacement
  1. ZTE Telstra T95 Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
  2. ZTE Telstra T95 Battery Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
Jeesenia Rios
300 Reputation
2 Guides authored
Gateway, Team 1-1, Johnson Fall 2014 Member of Gateway, Team 1-1, Johnson Fall 2014
GCC-JOHNSON-F14S1G1
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 361
