Zeepad 7.0 Screen Replacement
  1. Zeepad 7.0 Screen Replacement, Screen: step 1, image 1 of 2 Zeepad 7.0 Screen Replacement, Screen: step 1, image 2 of 2
    • Power off the device and keep it unplugged.
    • Open the case using a plastic opening tool around the edges. Slightly pull the cover off.
    • Do not completely remove back casing because there is a speaker attached to the back.
  2. Zeepad 7.0 Screen Replacement: step 2, image 1 of 1
    • Using the Phillips Head 0 bit, carefully unscrew the three 3.5mm screws holding the motherboard in place on to the back of the screen.
  3. Zeepad 7.0 Screen Replacement: step 3, image 1 of 2 Zeepad 7.0 Screen Replacement: step 3, image 2 of 2
    • Disconnect the two ribbon cables between the screen and the motherboard.
    • Be careful not to rip out the ribbon cables or you can harm the ports.
  4. Zeepad 7.0 Screen Replacement: step 4, image 1 of 1
    • Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each.
  5. Zeepad 7.0 Screen Replacement: step 5, image 1 of 2 Zeepad 7.0 Screen Replacement: step 5, image 2 of 2
    • Separate the front screen protector from the lcd screen. There are clamps holding the screen in place.
  6. Zeepad 7.0 Screen Replacement: step 6, image 1 of 3 Zeepad 7.0 Screen Replacement: step 6, image 2 of 3 Zeepad 7.0 Screen Replacement: step 6, image 3 of 3
    • Separate the LCD screen from the metal protecting case with the metal spudger.
  7. Zeepad 7.0 Screen Replacement: step 7, image 1 of 3 Zeepad 7.0 Screen Replacement: step 7, image 2 of 3 Zeepad 7.0 Screen Replacement: step 7, image 3 of 3
    • After creating space to work, warm up a soldering iron.
    • Apply heat onto the solder over the corresponding cut wires to the new screen wires.
    • How To Solder and Desolder Connections
    • The soldering iron will be extremely hot. Keep out of direct contact to other wires, the motherboard, and especially the battery.
    • Keep out of reach of children.
To reassemble your device, follow these instructions in order.
Harry Winter
157 Reputation
1 Guide authored
IUPUI, Team S2-G1, Harley Spring 2018 Member of IUPUI, Team S2-G1, Harley Spring 2018
IUPUI-HARLEY-S18S2G1
3 Members
4 Guides authored
2 Guide Comments
where do you buy the screen?
Zuzzi Z Amend - Reply
i need a battery an a screen? is their a place on this page where to get them?
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 627
