Zenbre SoundBank Z3 Control Interface Circuit Board Replacement
  1. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement, Bottom Cover: step 1, image 1 of 2 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement, Bottom Cover: step 1, image 2 of 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 2, image 1 of 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 3, image 1 of 2 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 3, image 2 of 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement, Motherboard Cover: step 4, image 1 of 3 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement, Motherboard Cover: step 4, image 2 of 3 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement, Motherboard Cover: step 4, image 3 of 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement, Battery: step 5, image 1 of 2 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement, Battery: step 5, image 2 of 2
    • Remove the battery from the holder. It may be difficult the first time.
    • Use a spudger between the battery and speaker wall to loosen it from its surroundings.
    • If the battery is punctured, leaking, or bloated/puffy, it may be hazardous and should be properly disposed of.
  6. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 6, image 1 of 2 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 6, image 2 of 2
    • Remove the pressure-fitted foam from the slot by hand.
    • Unravel and remove foam from the wires.
    • When reassembling, the foam can be re-wrapped if care is taken when handling it.
  7. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 7, image 1 of 1
    • Using a soldering iron, remove the leads, separating the battery from motherboard.
    • Follow this guide to help you remove the wires from the motherboard if you are unfamiliar with soldering.
  8. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement, Speakers: step 8, image 1 of 2 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement, Speakers: step 8, image 2 of 2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  9. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 9, image 1 of 2 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 9, image 2 of 2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  10. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 10, image 1 of 2 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 10, image 2 of 2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
  11. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement, Control Interface Circuit Board: step 11, image 1 of 2 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement, Control Interface Circuit Board: step 11, image 2 of 2
    • Remove the two 4.5 mm Phillips silver screws holding down the motherboard.
    • Note the ribbon that connects the motherboard to the control interface. Be careful with this while removing the motherboard, as it can tear easily.
    • Lift the motherboard out of its housing.
  12. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 12, image 1 of 2 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 12, image 2 of 2
    • Use an iFixit opening tool to lift up the ribbon connector.
    • Slide the ribbon cable out of its connector.
  13. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 13, image 1 of 1
    • Remove the four 4.5 mm Phillips silver screws.
    • Remove the six 7 mm Phillips black screws.
  14. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 14, image 1 of 3 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 14, image 2 of 3 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 14, image 3 of 3
    • Remove the top plastic cover by prying around the edges with an iFixit opening tool.
  15. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 15, image 1 of 3 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 15, image 2 of 3 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 15, image 3 of 3
    • Carefully remove the round black cover of the circuit board by using a spudger to pry it upward.
    • When working with electronics, it's important to choose a tool that is electrostatic discharge (ESD) safe in order to avoid accidental damage to the device. A metal spudger is great when you need serious prying power, but a regular black nylon spudger or a plastic tool should be used whenever possible.
    • Handle the cover plate carefully. Just like with the feet from before, it can be replaced if care is used when handling it.
    • Remove the four screws.
  16. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 16, image 1 of 2 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 16, image 2 of 2
    • Pick up the center power button and remove it. Place it in a safe location.
    • When you pick up the power button, the board will come right off. Be sure not to lose it.
  17. Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 17, image 1 of 3 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 17, image 2 of 3 Zenbre SoundBank Z3 Control Interface Circuit Board Replacement: step 17, image 3 of 3
    • Remove these four 7 mm black screws.
    • This will free the circuit board, which can now be lifted away from the housing.
    • If you wish to remove the ribbon here, use the same method used to remove the ribbon from the motherboard earlier in this guide.
Cherian Thomas
334 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 350
