Zerodate T26 Scroll Wheel Replacement
  1. Zerodate T26 Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 2 Zerodate T26 Scroll Wheel Replacement, Scroll Wheel: step 1, image 2 of 2
    • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
  2. Zerodate T26 Scroll Wheel Replacement: step 2, image 1 of 2 Zerodate T26 Scroll Wheel Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
    • Adhesive pads are located on the bottom of the mouse.
  3. Zerodate T26 Scroll Wheel Replacement: step 3, image 1 of 2 Zerodate T26 Scroll Wheel Replacement: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
  4. Zerodate T26 Scroll Wheel Replacement: step 4, image 1 of 2 Zerodate T26 Scroll Wheel Replacement: step 4, image 2 of 2
    • Carefully pull the middle shell apart from the bottom plate.
    • The circuit board should then be visible and attached to the bottom plate.
  5. Zerodate T26 Scroll Wheel Replacement: step 5, image 1 of 2 Zerodate T26 Scroll Wheel Replacement: step 5, image 2 of 2
    • Remove the scroll wheel by pushing it to the right and pulling up.
Janice Rullan
662 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 207
