Zipper Pull Replacement
Video Overview
Zipper pull replacement overview.
  1. Zipper Pull Replacement, Locate the zipper tab: step 1, image 1 of 3 Zipper Pull Replacement, Locate the zipper tab: step 1, image 2 of 3 Zipper Pull Replacement, Locate the zipper tab: step 1, image 3 of 3
    • This tutorial demonstrates how to insert a paracord pull with a rubber end, a common type of zipper pull on Patagonia products. These pulls come in a large size for main zippers and a small size for pockets (reference image #2).
    • If you need to remove a damaged zipper pull, skip to Step 6.
    • Locate the zipper slider that is missing a pull. The slider has a tab with two holes, one where the tab is attached to the slider body and one at the end of the tab.
  2. Zipper Pull Replacement, Insert the paracord end: step 2, image 1 of 2 Zipper Pull Replacement, Insert the paracord end: step 2, image 2 of 2
    • Pinch the paracord end of the pull and slide it into the tab hole that's closer to the slider.
    • It doesn't matter whether it's inserted from the top or bottom.
    • Pull the paracord through the tab hole.
    • Use pliers to help pinch the paracord and aid in this step, especially if the tab hole is small.
  3. Zipper Pull Replacement, Thread the pull through the second hole: step 3, image 1 of 2 Zipper Pull Replacement, Thread the pull through the second hole: step 3, image 2 of 2
    • Pinch the paracord end of the pull and thread it through the other hole on the slider tab, the one furthest from the slider body.
    • Now there will be a paracord loop emerging from this tab hole (reference red arrow, image #2).
  4. Zipper Pull Replacement, Loop the rubber end: step 4, image 1 of 2 Zipper Pull Replacement, Loop the rubber end: step 4, image 2 of 2
    • Thread the rubber end of the paracord pull through the loop emerging from the slider tab.
  5. Zipper Pull Replacement, Tighten the pull: step 5, image 1 of 2 Zipper Pull Replacement, Tighten the pull: step 5, image 2 of 2
    • While holding the slider, pull the rubber end of the zipper pull to tighten it. The zipper pull is now inserted and should lay flat on the slider tab.
    • To take off a damaged zipper pull, do these same steps in reverse.
    • Pliers can be helpful in getting into the small space and loosening the tension of the pull.
    • Discard the damaged pull responsibly.
Finish Line
5 other people completed this guide.
Brittany McCrigler
90,618 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,927 Guides authored
1 Guide Comment
Awesome! Thanks for the training!
Kathleen Hutton - Reply
Past 24 Hours: 44
Past 7 Days: 281
Past 30 Days: 1,137
All Time: 32,540
