Zoll Impact Uni-Vent 731 Battery Compartment Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Zoll Impact Uni-Vent 731 Battery Compartment Replacement, Battery Compartment Kit: step 1, image 1 of 1
    • Remove the battery compartment cover by unscrewing the (4) Phillips 6-32 X 5/16 screws. This is indicated in red with the number 1.
    • Page 25.
  2. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: step 2, image 1 of 2 Zoll Impact Uni-Vent 731 Battery Compartment Replacement: step 2, image 2 of 2
    • Remove the battery by unscrewing the (4)Phillips 6-32 X 2 ¼ screws and detaching the plug from its locking latch. This is indicated in the second picture in blue with the number 2.
    • Page 25.
  3. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: step 3, image 1 of 1
    • Unscrew the (4) 6-32 X 5/16 Phillips screws to remove the damaged battery compartment case.
    • Page 25.
  4. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: step 4, image 1 of 1
    • Rotate battery compartment to mate with upper and lower case cutouts and press firmly into place. Secure with (4) Phillips 6-32 X 5/16 screws provided.
    • Page 25.
  5. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: step 5, image 1 of 1
    • Re-assemble the battery by connecting its cable to the connector (pull on cable to insure it is locked in place) then tightening the (4) Phillips 6-32 X 2 ¼ screws. This is indicated in blue with the number 5.
    • Page 25.
  6. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: step 6, image 1 of 1
    • Re-assemble the battery compartment cover by tightening the (4) 6-32 X5/16 screws. This is indicated in red with the number 6.
    • Page 25.
  7. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: step 7, image 1 of 1
    • Perform HiPot Testing then perform Functional Test using the RCS to verify the replacement is working properly.
    • Page 25.
Michaela Fromm
150 Reputation
1 Guide authored
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Member of Cal Poly, Team S1-G5, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G5
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 347
