Zoll Impact Uni-Vent 731 Power Knob Kit Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement, Power Knob Kit: step 1, image 1 of 1
    • Loosen but do not remove the(4) 8-32 X 3 screws on the outer air intake
    • Pg. 29
  2. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 2, image 1 of 1
    • Loosen and remove the (2) 10-32 Keps nuts and the (4) 6-32 X 2 screws. Remove the back case by lifting from the ventilator
    • Pg. 29
  3. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 3, image 1 of 1
    • Remove the (2) 4-40 X ¼ screws on the Dovetail Mounting Bracket and disconnect the ribbon cable on the PIM PCB by simultaneously applying pressure on the two locking “ears”
    • Pg. 29
  4. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 4, image 1 of 1
    • Flip the ventilator over and remove the front case assembly by lifting it straight up away from the ventilator module
    • Pg. 29
  5. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 5, image 1 of 1
    • Remove the bezel by loosening and removing the (7) 4-40 X ¼ screws that hold the bezel to the front case
    • Pg. 29
  6. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 6, image 1 of 1
    • On the membrane panel assembly, loosen the 6-32 X ¼ set screw using a 1/16 Ball Hex Driver (located in the power knob) and lift the damaged knob from the membrane panel
    • Pg. 30
  7. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 7, image 1 of 1
    • Place the replacement knob on the membrane panel switch -align with flat on switch –insert the included 6-32 X ¼ set screw and tighten
    • Pg. 30
  8. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 8, image 1 of 1
    • Install the new bezel by tightening the included (7) 4-40 X ¼ screws
    • Pg. 30
  9. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 9, image 1 of 1
    • Place the front case assembly over the vent module and tighten the (2) 4-40 X ¼ screws unto the dovetail mounting bracket. Reconnect the ribbon cable unto the PIM PCB. Make sure the two locking “ears” lock into position
    • Pg. 30
  10. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 10, image 1 of 1
    • Attach the back case to the vent module and align cover with handle, air intake housing and dovetail mounting studs. Insert and tighten the included (2) 10-32 Keps nuts and the (4) 6-32 X 2” screws
    • Pg. 30
  11. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 11, image 1 of 1
    • Tighten the (4) 8-32 X 3 screws on the outer air intake
    • Pg. 30
  12. Zoll Impact Uni-Vent 731 Power Knob Kit Replacement: step 12, image 1 of 1
    • Perform HiPot Testing then perform Calibration and Functional Test using the RCS
    • Pg. 30
Emily
206 Reputation
1 Guide authored
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Member of Cal Poly, Team S1-G5, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G5
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 179
