Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement, SPM Vent Kit: step 1, image 1 of 1
    • Loosen but do not remove the(4) 8-32 X 3 screws on the outer air intake.
  2. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 2, image 1 of 2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 2, image 2 of 2
    • Loosen and remove the (2) 10-32 Keps nuts and the (4) 6-32 X 2 screws. Remove the back case by lifting from the ventilator.
  3. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 3, image 1 of 2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 3, image 2 of 2
    • Remove the (2) 4-40 X ¼ screws on the Dovetail Mounting Bracket and disconnect the ribbon cable on the PIM PCB by simultaneously applying pressure on the two locking “ears”.
  4. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 4, image 1 of 1
    • Flip the ventilator over and remove the front case assembly by lifting it straight up away from the ventilator module.
  5. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 5, image 1 of 3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 5, image 2 of 3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 5, image 3 of 3
    • Remove the battery compartment cover by unscrewing the (4) 6-32 X 5/16 screws.
  6. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 6, image 1 of 1
    • Remove the battery by unscrewing the (4) 6-32 X 2 ¼ screws and detaching the plug from its lockinglatch.
  7. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 7, image 1 of 1
    • Unscrew the (4) 6-32 X 5/16 Phillips screws to remove the damaged battery compartment case.
  8. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 8, image 1 of 1
    • Loosen and remove the (2) 4-40 X 1 ¼ Screws and nylon spacers supporting the Power Input assembly unto the chassis
  9. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 9, image 1 of 1
    • Loosen and remove the (2) 6-32 X ¼ screws holding the chassis to the dovetail mounting bracket and remove the SPO2 insulator. Loosen and remove the (2) 8-32 X ¼ screws holding the chassis to the vent module
  10. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 10, image 1 of 1
    • Insert screwdriver through the holes on the chassis to loosen and remove the (2) 6-32 x 5/16 screws holding the chassis to the vent module.
  11. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 11, image 1 of 1
    • Lift the damaged chassis from the ventilator module.
  12. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 12, image 1 of 1
    • Disconnect the Power Input cable from the PIM PCB by pressing on the locking latch and pulling the cable straight up from the connector.
  13. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 13, image 1 of 1
    • Remove the PIM PCB by loosening the (5) 4-40 X 5/16 screws.
  14. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 14, image 1 of 1
    • Remove the Dovetail stabilizer bracket by loosening and removing the (2) 6-32 x ¼ and the (2) 4-40 X ¼ screws.
  15. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 15, image 1 of 1
    • Install the dovetail stabilizer bracket ontothe new SPM assembly by tightening the (2) 6-32 X ¼ and (2) 4-40 X ¼ screws.
  16. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 16, image 1 of 1
    • Secure the PIM Board to the new SPM with the (5) 4-40 x 5/16 screws.
  17. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 17, image 1 of 1
    • Secure the chassis to the vent module using the (2) 6-32 X ¼ screws with SPO2 insulator, the (2) 8-32 X ¼ and the (2) 6-32 x 5/16 screws.
  18. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 18, image 1 of 1
    • Secure the Power Input assembly to the Chassis using the (2) spacers and (2) 4-40 X 1 ¼ screws. Do not over-tighten the screws.
  19. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 19, image 1 of 2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 19, image 2 of 2
    • Rotate battery compartment to mate with upper and lower case cutouts and press firmly into place. Secure with (4) 6-32 X 5/16 screws provided
  20. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 20, image 1 of 1
    • Re-assemble the battery by connecting its cable to the connector (pull on cable to insure it is locked in place) then tightening the (4) 6-32 X 2 ¼ screws.
  21. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 21, image 1 of 3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 21, image 2 of 3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 21, image 3 of 3
    • Re-assemble the battery compartment cover by tightening the (4) 6-32 X 5/16 screws.
  22. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 22, image 1 of 1
    • Place the front case assembly over the vent module and tighten the (2) 4-40 X ¼ screws unto the dovetail mounting bracket. Reconnect the ribbon cable unto the PIM PCB. Make sure the two locking “ears” lock into position.
  23. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 23, image 1 of 1
    • Attach the back case to the vent module and align cover with handle, air intake housing and dovetail mounting studs. Insert and tighten the included (2) 10-32 Keps nuts and the (4) 6-32 X 2” screws.
  24. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 24, image 1 of 2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 24, image 2 of 2
    • Tighten the (4) 8-32 X 3 screws on the outer air intake.
  25. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: step 25, image 1 of 1
    • Perform HiPot Testing then perform Calibration and Functional Test using the RCS.
Brandon Drury
391 Reputation
1 Guide authored
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Member of Cal Poly, Team S1-G5, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G5
5 Members
5 Guides authored
One Comment
Hi
What is the service passcode to reset the PM clock?
fayezhmc - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 343
