Zoom H1 Handy Recorder Battery Terminal Replacement
  1. Zoom H1 Handy Recorder Battery Terminal Replacement, Battery Terminal: step 1, image 1 of 1
    • Place the device so the display is down.
  2. Zoom H1 Handy Recorder Battery Terminal Replacement: step 2, image 1 of 1
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Zoom H1 Handy Recorder Battery Terminal Replacement: step 3, image 1 of 1
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
  4. Zoom H1 Handy Recorder Battery Terminal Replacement: step 4, image 1 of 1
    • Carefully pry up the top end of the back cover using one finger
  5. Zoom H1 Handy Recorder Battery Terminal Replacement: step 5, image 1 of 1
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  6. Zoom H1 Handy Recorder Battery Terminal Replacement: step 6, image 1 of 1
    • De-solder at terminal point one.
  7. Zoom H1 Handy Recorder Battery Terminal Replacement: step 7, image 1 of 1
    • De-solder at the second terminal point.
  8. Zoom H1 Handy Recorder Battery Terminal Replacement: step 8, image 1 of 2 Zoom H1 Handy Recorder Battery Terminal Replacement: step 8, image 2 of 2
    • Remove the faulty terminals
  9. Zoom H1 Handy Recorder Battery Terminal Replacement: step 9, image 1 of 1
    • Place new lead in at point one and re-solder at the point.
  10. Zoom H1 Handy Recorder Battery Terminal Replacement: step 10, image 1 of 1
    • Place second lead at point 2 and re-solder.
To Re-construct device, perform these steps in reverse order.
Alex
809 Reputation
5 Guides authored
7 Comments
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - Reply
Mine has third screw under the serial-number sticker.
halluciana - Reply
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - Reply
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - Reply
Same problem, without any reason it is dead
eevilcute -
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 33
All Time: 6,484
