Zoomer Dino Boomer Nose Sensor Replacement
  1. Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: step 1, image 1 of 2 Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: step 1, image 2 of 2
    • Unscrew the two 7.5 mm Phillips #0 screws at the base of the neck.
    • Remove the two 7.2 mm Phillips #0 screws above these at the base of the mouth.
  2. Zoomer Dino Boomer Nose Sensor Replacement: step 2, image 1 of 2 Zoomer Dino Boomer Nose Sensor Replacement: step 2, image 2 of 2
    • Use the spudger to pry Zoomer Dino Boomer's lower jaw from its mouth.
  3. Zoomer Dino Boomer Nose Sensor Replacement: step 3, image 1 of 2 Zoomer Dino Boomer Nose Sensor Replacement: step 3, image 2 of 2
    • Remove the roof of Zoomer Dino Boomer's mouth by unscrewing the 7.5 mm Phillips #0 screw.
  4. Zoomer Dino Boomer Nose Sensor Replacement: step 4, image 1 of 2 Zoomer Dino Boomer Nose Sensor Replacement: step 4, image 2 of 2
    • Carefully push the sensors out of the nose socket with your fingers.
  5. Zoomer Dino Boomer Nose Sensor Replacement: step 5, image 1 of 3 Zoomer Dino Boomer Nose Sensor Replacement: step 5, image 2 of 3 Zoomer Dino Boomer Nose Sensor Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Use a soldering iron to remove the wires from the sensor chip by melting the metal joints on the chip.
    • Use the tweezers to remove the wires as you are soldering them.
    • Do not touch any parts of Zoomer Dino Boomer or yourself when using the soldering iron. The soldering iron will be very hot.
    • When reassembling, extra solder may be required to reconnect the wires with the circuit board.
  6. Zoomer Dino Boomer Nose Sensor Replacement: step 6, image 1 of 1
    • Remove and replace the nose sensor.
Lauren Mannix
398 Reputation
3 Guides authored
USF Tampa, Team 16-1, Wollert Fall 2015 Member of USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 1,365
