Zoomer Jurassic World Indominus Rex Mouth Part Replacement
  1. Zoomer Jurassic World Indominus Rex Mouth Part Replacement, Mouth Part: step 1, image 1 of 2 Zoomer Jurassic World Indominus Rex Mouth Part Replacement, Mouth Part: step 1, image 2 of 2
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Mouth Part Replacement: step 2, image 1 of 3 Zoomer Jurassic World Indominus Rex Mouth Part Replacement: step 2, image 2 of 3 Zoomer Jurassic World Indominus Rex Mouth Part Replacement: step 2, image 3 of 3
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
Anh Le
504 Reputation
3 Guides authored
USF Tampa, Team 10-3, Remmell Spring 2016 Member of USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,163
