Zoomer Meowzies Legs Replacement
  1. Zoomer Meowzies  Legs Replacement, Legs: step 1, image 1 of 3 Zoomer Meowzies  Legs Replacement, Legs: step 1, image 2 of 3 Zoomer Meowzies  Legs Replacement, Legs: step 1, image 3 of 3
    • Using the Triangle driver remove the four 7.5 mm screws.
    • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
  2. Zoomer Meowzies  Legs Replacement: step 2, image 1 of 2 Zoomer Meowzies  Legs Replacement: step 2, image 2 of 2
    • Turn the device so that the the device is on its side.
    • Hold the back and belly on the device and gently pull apart.
    • Pulling with too much force might damage a few cables inside, so caution is needed.
  3. Zoomer Meowzies  Legs Replacement: step 3, image 1 of 3 Zoomer Meowzies  Legs Replacement: step 3, image 2 of 3 Zoomer Meowzies  Legs Replacement: step 3, image 3 of 3
    • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
Muataz Alahmadi
193 Reputation
2 Guides authored
USF Tampa, Team S6-G2, Eyestone Spring 2018 Member of USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
3 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 218
