Zoomer Meowzies Chest Senor Replacement
  1. Zoomer Meowzies Chest Senor Replacement, Legs: step 1, image 1 of 3 Zoomer Meowzies Chest Senor Replacement, Legs: step 1, image 2 of 3 Zoomer Meowzies Chest Senor Replacement, Legs: step 1, image 3 of 3
    • Using the Triangle driver remove the four 7.5 mm screws.
    • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
  2. Zoomer Meowzies Chest Senor Replacement: step 2, image 1 of 2 Zoomer Meowzies Chest Senor Replacement: step 2, image 2 of 2
    • Turn the device so that the the device is on its side.
    • Hold the back and belly on the device and gently pull apart.
    • Pulling with too much force might damage a few cables inside, so caution is needed.
  3. Zoomer Meowzies Chest Senor Replacement: step 3, image 1 of 3 Zoomer Meowzies Chest Senor Replacement: step 3, image 2 of 3 Zoomer Meowzies Chest Senor Replacement: step 3, image 3 of 3
    • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
  4. Zoomer Meowzies Chest Senor Replacement, Chest Senor: step 4, image 1 of 3 Zoomer Meowzies Chest Senor Replacement, Chest Senor: step 4, image 2 of 3 Zoomer Meowzies Chest Senor Replacement, Chest Senor: step 4, image 3 of 3
    • Carefully pry the ribbon cable from the connector.
    • Though we find it easier to use our fingers, the pry-tools may be useful.
  5. Zoomer Meowzies Chest Senor Replacement: step 5, image 1 of 3 Zoomer Meowzies Chest Senor Replacement: step 5, image 2 of 3 Zoomer Meowzies Chest Senor Replacement: step 5, image 3 of 3
    • For easier access to the sensor, tilt and pull the sensor away from the body.
  6. Zoomer Meowzies Chest Senor Replacement: step 6, image 1 of 3 Zoomer Meowzies Chest Senor Replacement: step 6, image 2 of 3 Zoomer Meowzies Chest Senor Replacement: step 6, image 3 of 3
    • To remove the sensors, use a soldering iron to solder the two points and remove the red and black wires from the reverse side.
    • The soldering iron is very hot, so take caution not to touch it directly in order to avoid burns.
  7. Zoomer Meowzies Chest Senor Replacement: step 7, image 1 of 2 Zoomer Meowzies Chest Senor Replacement: step 7, image 2 of 2
    • Turn the sensors over and locate the solder points of the remaining white wires. Heat the solder and remove the pair of wires.
    • The sensor should be completely detachable now.
Mitchell Gentry
675 Reputation
6 Guides authored
USF Tampa, Team S6-G2, Eyestone Spring 2018 Member of USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
3 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 483
