Zotac EN970 Storage Replacement
  1. Zotac EN970 Storage Replacement, Opening your machine: step 1, image 1 of 2 Zotac EN970 Storage Replacement, Opening your machine: step 1, image 2 of 2
    • Zotac uses thumb screws to secure the case. No tools required!
    • After you remove the thumb screws, just slide the bottom cover away from you and lift it away.
  2. Zotac EN970 Storage Replacement, Insert your drive: step 2, image 1 of 3 Zotac EN970 Storage Replacement, Insert your drive: step 2, image 2 of 3 Zotac EN970 Storage Replacement, Insert your drive: step 2, image 3 of 3
    • The EN970 has three hard drive connectors: 2 2.5" bays and 1 M.2 bay.
    • There are thumb screws for the 2.5" drives that secure plastic caddies that snap onto your drive
  3. Zotac EN970 Storage Replacement, M.2 Drive: step 3, image 1 of 2 Zotac EN970 Storage Replacement, M.2 Drive: step 3, image 2 of 2
    • The M.2 drive requires a phillips screwdriver for installation. Your ZBOX should have two screws inserted in two of the three pegs.
    • Remove the screws, insert your drive and use one screw to secure it. Be sure not to over-tighten.
9 other people completed this guide.
zdowns1
247 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 16
All Time: 1,397
