Zotac GTX 1080 Ti Mini Fans Replacement
  1. Zotac GTX 1080 Ti Mini Fans Replacement, Zotac GTX 1080 Ti Mini Fans: step 1, image 1 of 2 Zotac GTX 1080 Ti Mini Fans Replacement, Zotac GTX 1080 Ti Mini Fans: step 1, image 2 of 2
    • Be sure to properly ground yourself with an anti-static wristband before working on the graphics card.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the right side of the shroud.
  2. Zotac GTX 1080 Ti Mini Fans Replacement: step 2, image 1 of 2 Zotac GTX 1080 Ti Mini Fans Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the left side of the shroud.
  3. Zotac GTX 1080 Ti Mini Fans Replacement: step 3, image 1 of 2 Zotac GTX 1080 Ti Mini Fans Replacement: step 3, image 2 of 2
    • Look for the fan header located beside the 16-pin power connector.
    • Gently pry the fan connector apart from the header with a flathead screwdriver.
  4. Zotac GTX 1080 Ti Mini Fans Replacement: step 4, image 1 of 2 Zotac GTX 1080 Ti Mini Fans Replacement: step 4, image 2 of 2
    • Slowly and carefully lift the shroud off the heatsink.
    • During this step, make sure not to damage the LED connector that is still connecting the shroud to the PCB.
    • Flip the shroud along the top of the graphics card.
  5. Zotac GTX 1080 Ti Mini Fans Replacement: step 5, image 1 of 3 Zotac GTX 1080 Ti Mini Fans Replacement: step 5, image 2 of 3 Zotac GTX 1080 Ti Mini Fans Replacement: step 5, image 3 of 3
    • Remove the three 3 mm Phillips screws holding the fans to the heatsink with a Phillips #0 screwdriver.
    • Remove the broken fans.
  6. Zotac GTX 1080 Ti Mini Fans Replacement: step 6, image 1 of 3 Zotac GTX 1080 Ti Mini Fans Replacement: step 6, image 2 of 3 Zotac GTX 1080 Ti Mini Fans Replacement: step 6, image 3 of 3
    • Place the replacement fan on top of the heatsink with the screw holes aligned.
    • Screw the fans into place using a Phillips #0 screwdriver.
  7. Zotac GTX 1080 Ti Mini Fans Replacement: step 7, image 1 of 1
    • Reconnect the fan connector to its header.
  8. Zotac GTX 1080 Ti Mini Fans Replacement: step 8, image 1 of 3 Zotac GTX 1080 Ti Mini Fans Replacement: step 8, image 2 of 3 Zotac GTX 1080 Ti Mini Fans Replacement: step 8, image 3 of 3
    • Place the shroud back over the heatsink and screw it back into place using a Phillips #0 screwdriver.
Hopefully, your graphics card is fully replaced and completely working now.
Victor Pan
175 Reputation
1 Guide authored
One Comment
Do you know what size (diameter and thread) the 4mm and 3mm screws are?
cchagadorn - Reply
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 75
All Time: 4,856
