Zyxel USG 50 Unified Security Gateway Disassembly
  1. Zyxel USG 50 Unified Security Gateway Disassembly, Removing the screws: step 1, image 1 of 3 Zyxel USG 50 Unified Security Gateway Disassembly, Removing the screws: step 1, image 2 of 3 Zyxel USG 50 Unified Security Gateway Disassembly, Removing the screws: step 1, image 3 of 3
    • Screws
    • Frame kit for the rack (ears)
  2. Zyxel USG 50 Unified Security Gateway Disassembly, Removing DB9 connector: step 2, image 1 of 2 Zyxel USG 50 Unified Security Gateway Disassembly, Removing DB9 connector: step 2, image 2 of 2
    • To remove the cover it is necessary to disconnect the DB9 connector
  3. Zyxel USG 50 Unified Security Gateway Disassembly, Removing the lid: step 3, image 1 of 2 Zyxel USG 50 Unified Security Gateway Disassembly, Removing the lid: step 3, image 2 of 2
    • The lid comes out when sliding
  4. Zyxel USG 50 Unified Security Gateway Disassembly, Motherboard: step 4, image 1 of 3 Zyxel USG 50 Unified Security Gateway Disassembly, Motherboard: step 4, image 2 of 3 Zyxel USG 50 Unified Security Gateway Disassembly, Motherboard: step 4, image 3 of 3
    • To remove the motherboard it is necessary to remove the 6 screws that fix it to the chassis
    • If the device does not save the time, you can replace the battery
    • CR2032 3 Volt Lithium
  5. Zyxel USG 50 Unified Security Gateway Disassembly, Chasis: step 5, image 1 of 1
    • The rubbers prevent the plate from contacting the chassis.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Eneider Colina
2,370 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,164
