Introduction
Follow these steps for a quick screen replacement on bObi Pet, or see this video guide: https://www.youtube.com/watch?v=EY-MMWtO...
Before we get started, turn bObi Pet OFF and flip her over onto a flat surface.
Next, remove bObi Pet's dustbin. Grip the small tab on the back of the bin, and pull to remove.
Grip the front wheel and pull straight up, using the screwdriver for leverage.
The wheel will pop out and you will see two screws beneath it.
There is a larger screw set deeper in the wheel compartment. Use the screwdriver to remove it.
Remove the screws on both sides of bObi Pet’s dustbin. Then, remove the corner pieces that were held down by the screws.
Grip the brush compartment and pull down to reveal two screws on a red fastener.
Remove them with the screwdriver.
Pull the brush compartment up until the fastener is freed from bObi Pet. Then, detach the brush compartment's circuit plug and set it aside.
Remove the 4 screws located beneath the brush compartment.
Remove the 2 screws on the dustbin’s red fastener.
Remove the fastener and set it aside for reassembly.
The cover is no longer secured, so carefully flip bObi Pet onto her wheels.
Lift the cover to reveal the main board underneath.
Remove the two circuit plugs connecting the lid to the mainboard.
bObi Pet's cover is entirely separated, and you may now access any of her internal parts for replacement.
Remove the four screws holding bObi Pet's screen.
Then, lift it straight up and out to make space for the replacement.
Lay the new screen in the open space on bObi Pet's lid.
Align the screw holes on the screen with the screw posts in bObi Pet and push down until it lies flat.
Install all four screws, and you'll be ready to close bObi Pet. See the following instructions: Assemble bObi Pet Post-Repair
To reassemble bObi Pet, see this tutorial: Assemble bObi Pet Post-Repair
