Introduction
These steps go through opening bObi's cover then on to removal of floor and ledge detection sensors. To close bObi, refer to the guide: Closing bObi's Cover Post-Repair
Remove bObi’s front wheel to access one of the screws holding bObi together.
Uninstall the larger screw that sits deeper in the wheel compartment.
The four floor detecting sensors plug in on the left of bObi’s front wheel. Pull to unplug it.
If the wires are glued down to bObi’s frame, simply pull up to detach them, then remove the circuit plug.
Place your new ground sensors in the open spaces and install one screw on each. You may add glue or electrical tape to the new wheel’s circuit plug for an extra secure hold while bObi works.
Attach the circuit plug to bObi’s main board, and the repair is complete. For instructions on closing bObi, see Closing bObi's Cover Post-Repair
To reassemble your device, follow the guide for Closing bObi.
