bObi Robotic Vacuum Power Switch Replacement
  1. bObi Robotic Vacuum Power Switch Replacement, Top Cover: step 1, image 1 of 2 bObi Robotic Vacuum Power Switch Replacement, Top Cover: step 1, image 2 of 2
    • Remove bObi’s front wheel to access one of the screws holding bObi together.
    • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
    • Uninstall the larger screw that sits deeper in the wheel compartment.
  2. bObi Robotic Vacuum Power Switch Replacement: step 2, image 1 of 3 bObi Robotic Vacuum Power Switch Replacement: step 2, image 2 of 3 bObi Robotic Vacuum Power Switch Replacement: step 2, image 3 of 3
    • Remove bObi's dustbin.
    • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  3. bObi Robotic Vacuum Power Switch Replacement: step 3, image 1 of 3 bObi Robotic Vacuum Power Switch Replacement: step 3, image 2 of 3 bObi Robotic Vacuum Power Switch Replacement: step 3, image 3 of 3
    • Lift the brush holder. To detach completely, unplug it from bObi.
    • Remove the two screws on the dustbin contact point holder inside bObi.
    • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  4. bObi Robotic Vacuum Power Switch Replacement: step 4, image 1 of 3 bObi Robotic Vacuum Power Switch Replacement: step 4, image 2 of 3 bObi Robotic Vacuum Power Switch Replacement: step 4, image 3 of 3
    • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  5. bObi Robotic Vacuum Power Switch Replacement, Power Switch: step 5, image 1 of 3 bObi Robotic Vacuum Power Switch Replacement, Power Switch: step 5, image 2 of 3 bObi Robotic Vacuum Power Switch Replacement, Power Switch: step 5, image 3 of 3
    • Slide the power switch up and out of its holder.
    • Unplug its wires from the main board.
  6. bObi Robotic Vacuum Power Switch Replacement: step 6, image 1 of 3 bObi Robotic Vacuum Power Switch Replacement: step 6, image 2 of 3 bObi Robotic Vacuum Power Switch Replacement: step 6, image 3 of 3
    • Slide the new power switch into the holders on bObi.
    • Plug it in to the main board and begin closing bObi up. For steps on how to close bObi, see Closing bObi's Cover Post-Repair
To reassemble your device, follow the guide on closing bObi Closing bObi's Cover Post-Repair
Chelsea
2,278 Reputation
31 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 298
