bObi Robotic Vacuum Touch Sensors Replacement
  1. bObi Robotic Vacuum Touch Sensors Replacement, Top Cover: step 1, image 1 of 2 bObi Robotic Vacuum Touch Sensors Replacement, Top Cover: step 1, image 2 of 2
    • Remove bObi’s front wheel to access one of the screws holding bObi together.
    • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
    • Uninstall the larger screw that sits deeper in the wheel compartment.
  2. bObi Robotic Vacuum Touch Sensors Replacement: step 2, image 1 of 3 bObi Robotic Vacuum Touch Sensors Replacement: step 2, image 2 of 3 bObi Robotic Vacuum Touch Sensors Replacement: step 2, image 3 of 3
    • Remove bObi's dustbin.
    • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  3. bObi Robotic Vacuum Touch Sensors Replacement: step 3, image 1 of 3 bObi Robotic Vacuum Touch Sensors Replacement: step 3, image 2 of 3 bObi Robotic Vacuum Touch Sensors Replacement: step 3, image 3 of 3
    • Lift the brush holder. To detach completely, unplug it from bObi.
    • Remove the two screws on the dustbin contact point holder inside bObi.
    • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  4. bObi Robotic Vacuum Touch Sensors Replacement: step 4, image 1 of 3 bObi Robotic Vacuum Touch Sensors Replacement: step 4, image 2 of 3 bObi Robotic Vacuum Touch Sensors Replacement: step 4, image 3 of 3
    • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  5. bObi Robotic Vacuum Touch Sensors Replacement, Touch Sensors: step 5, image 1 of 2 bObi Robotic Vacuum Touch Sensors Replacement, Touch Sensors: step 5, image 2 of 2
    • The sensor strips underneath bObi's 80 exterior touch sensors are attached to the cover circuit board by two wires, one red one white.
    • The circuit plug on the left communicates with bObi's right half of touch sensors.
    • The plug on the right controls bObi's left half of touch sensors.
    • Remove the appropriate touch sensor's circuit plug from the cover's circuit board.
  6. bObi Robotic Vacuum Touch Sensors Replacement: step 6, image 1 of 3 bObi Robotic Vacuum Touch Sensors Replacement: step 6, image 2 of 3 bObi Robotic Vacuum Touch Sensors Replacement: step 6, image 3 of 3
    • Feed both wires towards the end of the bumper.
    • Continue along the inside edge of the bumper until the wires are unhooked from each holder.
    • Then, pull both out from the post at the bumper's edge.
    • Pull each wire to the side to disconnect it from the touch sensor adapter.
  7. bObi Robotic Vacuum Touch Sensors Replacement: step 7, image 1 of 3 bObi Robotic Vacuum Touch Sensors Replacement: step 7, image 2 of 3 bObi Robotic Vacuum Touch Sensors Replacement: step 7, image 3 of 3
    • Plug in the white wire to the bottom touch strip connector, and the red one on top.
    • Tuck the wires behind the white post at the end of the bumper. Then, feed them back through the hooks.
  8. bObi Robotic Vacuum Touch Sensors Replacement: step 8, image 1 of 2 bObi Robotic Vacuum Touch Sensors Replacement: step 8, image 2 of 2
    • Firmly press the circuit plug for the replacement sensor in to the open space.
    • To put bObi back together, follow the steps in the reassembly guide: Closing bObi's Cover Post-Repair
For instructions on how to reassemble bObi's cover, check out the guide Closing bObi's Cover Post-Repair
Chelsea
2,278 Reputation
31 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 232
