bObsweep PetHair Plus WPP56002 LED Screen Replacement
  1. bObsweep PetHair Plus WPP56002 LED Screen Replacement, Cover: step 1, image 1 of 1
    • Depress the tab on the side of the dustbin to disengage its latch. It is spring loaded and will partially pop out. Remove it from its housing.
  2. bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 2, image 1 of 3 bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 2, image 2 of 3 bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 2, image 3 of 3
    • Flip the bObsweep over and remove the main brush’s screw (13.7mm Flat) with a flathead screwdriver.
    • Lift and remove the main brush and its plastic bearing end cap.
  3. bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 3, image 1 of 2 bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 3, image 2 of 2
    • Remove the two screws (9.9mm Phillips #1) next to the rotating front wheel.
    • Remove the two screws (9.9mm Phillips #1) below the wheels on either side of the dustbin compartment.
    • Remove the screw (9.9mm Phillips #1) to the side of the brush motor.
    • Remove the screw (9.9mm Phillips #1) inside the brush compartment.
  4. bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 4, image 1 of 2 bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 4, image 2 of 2
    • Carefully hold the top and bottom halves together and flip the bObsweep upright.
    • Lift the cover to reveal the mainboard.
  5. bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 5, image 1 of 3 bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 5, image 2 of 3 bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 5, image 3 of 3
    • Slide the power inlet down.
    • Tuck it aside to protect it from damage.
  6. bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 6, image 1 of 3 bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 6, image 2 of 3 bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 6, image 3 of 3
    • Depress the tabs on the circuit plugs and lift them directly upward to remove:
    • The multicolored nine-wire circuit plug at the top edge of the board.
    • The red and black wire circuit plug directly next to it.
    • The seven white wire circuit plug on the bottom edge of the board.
    • The red, white, and black wire circuit plug on the bottom left corner of the board.
  7. bObsweep PetHair Plus WPP56002 LED Screen Replacement, LED Screen: step 7, image 1 of 2 bObsweep PetHair Plus WPP56002 LED Screen Replacement, LED Screen: step 7, image 2 of 2
    • Remove and set aside the four screws (9.7 mm Phillips #1) on the underside of the cover that secure the screen.
  8. bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 8, image 1 of 1
    • Lift the screen out, moving aside any wires as needed.
  9. bObsweep PetHair Plus WPP56002 LED Screen Replacement: step 9, image 1 of 1
    • Align the new screen facedown with the screw posts on the cover.
Saylor Price
957 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 46
