d.light Solar Lantern S2 Battery Replacement
  1. d.light Solar Lantern S2 Battery Replacement, Battery: step 1, image 1 of 2 d.light Solar Lantern S2 Battery Replacement, Battery: step 1, image 2 of 2
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Battery Replacement: step 2, image 1 of 3 d.light Solar Lantern S2 Battery Replacement: step 2, image 2 of 3 d.light Solar Lantern S2 Battery Replacement: step 2, image 3 of 3
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Battery Replacement: step 3, image 1 of 3 d.light Solar Lantern S2 Battery Replacement: step 3, image 2 of 3 d.light Solar Lantern S2 Battery Replacement: step 3, image 3 of 3
    • Take the battery out of its setting. It is only held in by friction (no snaps or screws).
    • Disconnect the battery by unpluging the white connector.
    • Install the new battery
4 other people completed this guide.
Jeremiah Rhoades
435 Reputation
3 Guides authored
IUPUI, Team S2-G3, Harley Fall 2017 Member of IUPUI, Team S2-G3, Harley Fall 2017
IUPUI-HARLEY-F17S2G3
3 Members
3 Guides authored
One Comment
thanks for this.
You didn’t mention the model/name of the battery replacement. Can you help with that?
Albert H - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 50
All Time: 2,186
