dreamGEAR Quad Dock Pro Mother Board Replacement
  1. dreamGEAR Quad Dock Pro Mother Board Replacement, Prerequisite Guide to Accessing Interior: step 1, image 1 of 2 dreamGEAR Quad Dock Pro Mother Board Replacement, Prerequisite Guide to Accessing Interior: step 1, image 2 of 2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Mother Board Replacement: step 2, image 1 of 2 dreamGEAR Quad Dock Pro Mother Board Replacement: step 2, image 2 of 2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Mother Board Replacement: step 3, image 1 of 1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Mother Board Replacement, Mother Board: step 4, image 1 of 2 dreamGEAR Quad Dock Pro Mother Board Replacement, Mother Board: step 4, image 2 of 2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Mother Board Replacement: step 5, image 1 of 1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Mother Board Replacement: step 6, image 1 of 2 dreamGEAR Quad Dock Pro Mother Board Replacement: step 6, image 2 of 2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
Jacob
757 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 238
