dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement
  1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: step 1, image 1 of 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: step 1, image 2 of 2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: step 2, image 1 of 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: step 2, image 2 of 2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: step 3, image 1 of 1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: step 4, image 1 of 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: step 4, image 2 of 2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: step 5, image 1 of 1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: step 6, image 1 of 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: step 6, image 2 of 2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: step 7, image 1 of 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: step 7, image 2 of 2
    • Remove the four 1.8 mm PH0 screws that are holding the board in.
    • When you remove these screws, the plastic cups inside the PS Move stations will fall out.
  8. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: step 8, image 1 of 1
    • Pick up the board.
    • Pick the board straight up, or you risk damaging the charging ports.
  9. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: step 9, image 1 of 1
    • Using a plastic opening tool or a similar tool, gently pry the power ribbon cord out of its port.
Jacob
757 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 219
