Help
PowerBook G4 Aluminum 15" 1.67 GHz Upper Case Replacement
Editing Step 3 —
Notice: You are now editing a prerequisite to the guide you were just viewing. Any changes you make will affect all 26 guides that include this step.
Step Type:
Drag to rearrange
Rotate the computer 90 degrees clockwise so the power receptacle faces you.
Remove the three 3 mm Phillips screws along the edge of the lower case.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer.
