headphone jack Replacement
  1. headphone jack Replacement, headphone jack: step 1, image 1 of 1
    • Turn the phone off.
  2. headphone jack Replacement: step 2, image 1 of 1
    • Remove the back panel with an opener tool.
  3. headphone jack Replacement: step 3, image 1 of 1
    • Lift out the battery using an opener tool.
  4. headphone jack Replacement: step 4, image 1 of 1
    • Remove the SIM and SD card.
  5. headphone jack Replacement: step 5, image 1 of 1
    • Remove the 10 4 mm Phillips screws on the back of the phone using the #00 Phillips screwdriver.
  6. headphone jack Replacement: step 6, image 1 of 1
    • Starting at the USB jack, slide the opener around the perimeter of the phone between the rear case and the frame. This will loosen the clips.
  7. headphone jack Replacement: step 7, image 1 of 1
    • Carefully remove the back case and middle frame and expose the inside of the phone.
  8. headphone jack Replacement: step 8, image 1 of 1
    • Disconnect the foil cable.
  9. headphone jack Replacement: step 9, image 1 of 1
    • Lift the corner of the board and remove the audio jack.
Work the steps in the reverse order to assemble your device again.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Peter Hübner
409 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 62
All Time: 1,472
