iBook G4 14" 933 MHz-1.33 GHz LCD Replacement
  1. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement, Battery: step 1, image 1 of 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 2, image 1 of 1
    • Lift the battery out of the computer.
  3. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement, Rear Display Bezel: step 3, image 1 of 2 iBook G4 14" 933 MHz-1.33 GHz LCD Replacement, Rear Display Bezel: step 3, image 2 of 2
    • Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  4. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 4, image 1 of 2 iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 4, image 2 of 2
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  5. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 5, image 1 of 1
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  6. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 6, image 1 of 2 iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 6, image 2 of 2
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  7. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 7, image 1 of 1
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  8. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 8, image 1 of 1
    • Lift the rear bezel off the display assembly.
  9. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement, LCD: step 9, image 1 of 2 iBook G4 14" 933 MHz-1.33 GHz LCD Replacement, LCD: step 9, image 2 of 2
    • Close the display.
    • Remove the several pieces of tape securing the thin metal LCD cover to the display.
    • Carefully remove the piece of foil tape covering the display data cable connection.
  10. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 10, image 1 of 2 iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 10, image 2 of 2
    • Remove the Phillips screw near the right display hinge.
    • Use the tip of a spudger to remove the small spacer under the screw you just removed.
  11. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 11, image 1 of 1
    • Pull the foil/braided pieces of tape off the aluminum frame of the clutch hinges.
    • Leave the tape attached to the thin steel LCD cover.
  12. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 12, image 1 of 2 iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 12, image 2 of 2
    • Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total).
  13. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 13, image 1 of 1
    • Carefully remove the thin steel LCD cover.
  14. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 14, image 1 of 1
    • Disconnect the display data cable by pulling the cable away from the socket on the LCD.
  15. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 15, image 1 of 1
    • Remove the strip of yellow tape securing the display data cable to the metal LCD frame.
  16. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 16, image 1 of 2 iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 16, image 2 of 2
    • Disconnect the backlight cable from the inverter.
    • It is helpful to use a spudger to push the backlight connector away from its socket while you lightly pull its cables away from the inverter.
  17. iBook G4 14" 933 MHz-1.33 GHz LCD Replacement: step 17, image 1 of 1
    • Lift the LCD out of the display assembly.
    • It may be helpful to press the latch release button and open your display slightly to push the LCD out of the display assembly.
5 other people completed this guide.
Attached Documents
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 9
All Time: 7,703
