iHome IH11 Control Buttons Replacement
  1. iHome IH11 Control Buttons Replacement, Outer Case: step 1, image 1 of 1
    • Unscrew the two 9.0 mm screws with the Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Control Buttons Replacement: step 2, image 1 of 2 iHome IH11 Control Buttons Replacement: step 2, image 2 of 2
    • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
    • Repeat the previous step for the two screws on the bottom.
  3. iHome IH11 Control Buttons Replacement: step 3, image 1 of 1
    • Remove the two 9mm screws from the top of the iHome with a Phillips #1 Screwdriver.
  4. iHome IH11 Control Buttons Replacement: step 4, image 1 of 1
    • Pop the dock connector out of the iHome and gently pull the white plastic plug from the dock connector.
  5. iHome IH11 Control Buttons Replacement: step 5, image 1 of 1
    • Carefully pull apart the device.
    • Remove the four screws that hold the circuit board for the buttons.
  6. iHome IH11 Control Buttons Replacement: step 6, image 1 of 1
    • Desolder the four connections for the broken button.
    • Solder the new button in the place of the old one.
    • For more information about soldering, refer to the soldering device page. Soldering Skills
Courtney Steinberg
35 Reputation
3 Guides authored
Cal Poly, Team 14-9, Maness Spring 2013 Member of Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 417
