iHome iAVS16 Motherboard Replacement
  1. iHome iAVS16 Motherboard Replacement, Power Board: step 1, image 1 of 3 iHome iAVS16 Motherboard Replacement, Power Board: step 1, image 2 of 3 iHome iAVS16 Motherboard Replacement, Power Board: step 1, image 3 of 3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 Motherboard Replacement: step 2, image 1 of 3 iHome iAVS16 Motherboard Replacement: step 2, image 2 of 3 iHome iAVS16 Motherboard Replacement: step 2, image 3 of 3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 Motherboard Replacement: step 3, image 1 of 2 iHome iAVS16 Motherboard Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 Motherboard Replacement: step 4, image 1 of 3 iHome iAVS16 Motherboard Replacement: step 4, image 2 of 3 iHome iAVS16 Motherboard Replacement: step 4, image 3 of 3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 Motherboard Replacement, LCD (Display): step 5, image 1 of 3 iHome iAVS16 Motherboard Replacement, LCD (Display): step 5, image 2 of 3 iHome iAVS16 Motherboard Replacement, LCD (Display): step 5, image 3 of 3
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 Motherboard Replacement: step 6, image 1 of 1
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 Motherboard Replacement: step 7, image 1 of 3 iHome iAVS16 Motherboard Replacement: step 7, image 2 of 3 iHome iAVS16 Motherboard Replacement: step 7, image 3 of 3
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
  8. iHome iAVS16 Motherboard Replacement, Motherboard: step 8, image 1 of 1
    • Flip up the back of the device encasing the motherboard.
  9. iHome iAVS16 Motherboard Replacement: step 9, image 1 of 3 iHome iAVS16 Motherboard Replacement: step 9, image 2 of 3 iHome iAVS16 Motherboard Replacement: step 9, image 3 of 3
    Buy
    • Using tweezers, unplug the white, red, and blue connectors from the motherboard by pulling each out.
  10. iHome iAVS16 Motherboard Replacement: step 10, image 1 of 1
    • Carefully unplug the ribbon cable, making sure not to rip it.
James Hoye
97 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 227
