iHome iAVS16 Power Board Replacement
  1. iHome iAVS16 Power Board Replacement, Power Board: step 1, image 1 of 3 iHome iAVS16 Power Board Replacement, Power Board: step 1, image 2 of 3 iHome iAVS16 Power Board Replacement, Power Board: step 1, image 3 of 3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 Power Board Replacement: step 2, image 1 of 3 iHome iAVS16 Power Board Replacement: step 2, image 2 of 3 iHome iAVS16 Power Board Replacement: step 2, image 3 of 3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 Power Board Replacement: step 3, image 1 of 2 iHome iAVS16 Power Board Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 Power Board Replacement: step 4, image 1 of 3 iHome iAVS16 Power Board Replacement: step 4, image 2 of 3 iHome iAVS16 Power Board Replacement: step 4, image 3 of 3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
Ashley Famularo
181 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 124
