iHome iBT16 Base Plate Replacement
  1. iHome iBT16 Base Plate Replacement, Base Plate: step 1, image 1 of 2 iHome iBT16 Base Plate Replacement, Base Plate: step 1, image 2 of 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Base Plate Replacement: step 2, image 1 of 2 iHome iBT16 Base Plate Replacement: step 2, image 2 of 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
Ryan Edwards
331 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 229
