iHome iBT25 Speaker Replacement
  1. iHome iBT25 Speaker Replacement, Exterior: step 1, image 1 of 2 iHome iBT25 Speaker Replacement, Exterior: step 1, image 2 of 2
    • Unplug the device and remove the front grille with your hands.
  2. iHome iBT25 Speaker Replacement: step 2, image 1 of 3 iHome iBT25 Speaker Replacement: step 2, image 2 of 3 iHome iBT25 Speaker Replacement: step 2, image 3 of 3
    • You can use this guide to replace either one, or both speakers.
  3. iHome iBT25 Speaker Replacement: step 3, image 1 of 2 iHome iBT25 Speaker Replacement: step 3, image 2 of 2
    • Remove the 4 screws surrounding the speaker you want to remove with a phillips head screwdriver
    • All the screws are the same size
  4. iHome iBT25 Speaker Replacement: step 4, image 1 of 2 iHome iBT25 Speaker Replacement: step 4, image 2 of 2
    • The speaker can now be pulled out or removed by tilting the device.
  5. iHome iBT25 Speaker Replacement: step 5, image 1 of 3 iHome iBT25 Speaker Replacement: step 5, image 2 of 3 iHome iBT25 Speaker Replacement: step 5, image 3 of 3
    • The speakers use color coded wires, which don't fit into the wrong side, so you can't get the sides mized up.
    • To remove a wire, grip it where the wire part meets the metal beneath the plastic protector (which is not necessary to remove)
    • pull away from the connector. The black socket is narrower than the red socket.
  6. iHome iBT25 Speaker Replacement, That's it!: step 6, image 1 of 3 iHome iBT25 Speaker Replacement, That's it!: step 6, image 2 of 3 iHome iBT25 Speaker Replacement, That's it!: step 6, image 3 of 3
    • That's it! Great job!
    • You saved money by doing it yourself, using only a Phillips-head screwdriver!
9021007
4,599 Reputation
25 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 115
