iHome iM71SC Base LED Replacement
  1. iHome iM71SC Base LED Replacement, iHome iM71SC Disassembly: step 1, image 1 of 1
    • Push down and turn the top of the speaker clockwise. This will release the clips and expand the speaker.
  2. iHome iM71SC Base LED Replacement: step 2, image 1 of 1
    • Use a #000 Phillips screwdriver to remove the four 1 mm screws from the bottom half of the speaker.
  3. iHome iM71SC Base LED Replacement: step 3, image 1 of 1
    • Flip the speaker over and use a #000 Phillips screwdriver to remove three 1mm screws . Unscrew these to unfasten the top.
  4. iHome iM71SC Base LED Replacement: step 4, image 1 of 1
    • Remove the now unfastened coverings to expose the internals of the speaker.
  5. iHome iM71SC Base LED Replacement, Base LED: step 5, image 1 of 1
    • Locate the LED on the circuit board.
  6. iHome iM71SC Base LED Replacement: step 6, image 1 of 2 iHome iM71SC Base LED Replacement: step 6, image 2 of 2
    • Desolder the three connections to the old LED to remove it from the board.
    • Check out this awesome guide for soldering & desoldering instructions.
To reassemble your device, follow Steps 1-4 in reverse order.
Sarah Brown
301 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 221
