iHome iM71SC Battery Replacement
  1. iHome iM71SC Battery Replacement, iHome iM71SC Disassembly: step 1, image 1 of 1
    • Push down and turn the top of the speaker clockwise. This will release the clips and expand the speaker.
  2. iHome iM71SC Battery Replacement: step 2, image 1 of 1
    • Use a #000 Phillips screwdriver to remove the four 1 mm screws from the bottom half of the speaker.
  3. iHome iM71SC Battery Replacement: step 3, image 1 of 1
    • Flip the speaker over and use a #000 Phillips screwdriver to remove three 1mm screws . Unscrew these to unfasten the top.
  4. iHome iM71SC Battery Replacement: step 4, image 1 of 1
    • Remove the now unfastened coverings to expose the internals of the speaker.
  5. iHome iM71SC Battery Replacement, Battery: step 5, image 1 of 3 iHome iM71SC Battery Replacement, Battery: step 5, image 2 of 3 iHome iM71SC Battery Replacement, Battery: step 5, image 3 of 3
    • Locate the battery underneath the circuit board.
  6. iHome iM71SC Battery Replacement: step 6, image 1 of 2 iHome iM71SC Battery Replacement: step 6, image 2 of 2
    • Unsolder the batterie's wires from the circuit board to remove the old battery.
    • Check out this awesome guide for soldering & desoldering instructions.
To reassemble your device, follow Steps 1-4 in reverse order.
Sarah Brown
301 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 262
