iHome iP1 Buttons Replacement
  1. iHome iP1 Buttons Replacement, Dock Cover: step 1, image 1 of 1
    • Orient the iHome upside down with the speakers facing you.
  2. iHome iP1 Buttons Replacement: step 2, image 1 of 1
    • Remove the two 9.5 mm Phillips #1 screws from the dock cover.
  3. iHome iP1 Buttons Replacement: step 3, image 1 of 3 iHome iP1 Buttons Replacement: step 3, image 2 of 3 iHome iP1 Buttons Replacement: step 3, image 3 of 3
    • Remove the dock cover by grabbing its sides and pulling it up and away from the faceplate.
  4. iHome iP1 Buttons Replacement, Buttons: step 4, image 1 of 2 iHome iP1 Buttons Replacement, Buttons: step 4, image 2 of 2
    • Disconnect the silver ribbon cable on the left-hand side by pulling away from the command buttons.
  5. iHome iP1 Buttons Replacement: step 5, image 1 of 3 iHome iP1 Buttons Replacement: step 5, image 2 of 3 iHome iP1 Buttons Replacement: step 5, image 3 of 3
    • Remove the command buttons by pulling the small black panel containing them downward and away from the faceplate.
Wen Sullivan
527 Reputation
4 Guides authored
Cal Poly, Team 20-1, Livingston Fall 2016 Member of Cal Poly, Team 20-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G1
4 Members
7 Guides authored
1 Guide Comment
Where can I buy the button PCB
David Ivar - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 680
