Introduction
Use this guide to replace your iHome iP1's damaged faceplate and/or damaged or faulty tweeters. The iHome iP1's faceplate and tweeters are connected to each other and cannot be detached from each other, so in order to replace one, the other must also be replaced. Note that replacing the faceplate and tweeters takes the most time to do, compared to the iHome iP1's other components. This is because the faceplate provides most of the structural support to the iHome iP1 and helps connect most of its components to each other.
Disconnect the silver ribbon cable on the left-hand side by pulling away from the command buttons.
Disconnect the white/black wires from the edges of the motherboard by pulling them away from their connection.
Disconnect the two red/black wire bundles located on the upper corners of the motherboard by pulling them away from their connection.
