Introduction
After replacing the battery and charging problems still persist, use this guide to replace the charging node.
Remove the rubber from the bottom of the speaker, use a medium blue plastic spudger to gently work its way under the rubber and slowly peel off for each of the three feet. The order does not matter.
Unscrew the two 11 mm Philips #1 screws on the charging nodes.
Remove the charging node from the speaker and set aside.
Almost done!
