iLive IKBC384S FM/AM Antenna Replacement
  1. iLive IKBC384S  FM/AM Antenna Replacement, Top Cover: step 1, image 1 of 2 iLive IKBC384S  FM/AM Antenna Replacement, Top Cover: step 1, image 2 of 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S  FM/AM Antenna Replacement: step 2, image 1 of 2 iLive IKBC384S  FM/AM Antenna Replacement: step 2, image 2 of 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S  FM/AM Antenna Replacement: step 3, image 1 of 2 iLive IKBC384S  FM/AM Antenna Replacement: step 3, image 2 of 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S  FM/AM Antenna Replacement, FM/AM Antenna: step 4, image 1 of 2 iLive IKBC384S  FM/AM Antenna Replacement, FM/AM Antenna: step 4, image 2 of 2
    • Remove all four screws(13.5 mm in length) that are securing the disk drive.
  5. iLive IKBC384S  FM/AM Antenna Replacement: step 5, image 1 of 2 iLive IKBC384S  FM/AM Antenna Replacement: step 5, image 2 of 2
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Also, disconnect the two power connectors from the motherboard.
    • Once you have removed the ribbon cables and two connectors on the motherboard the disk drive can be removed.
  6. iLive IKBC384S  FM/AM Antenna Replacement: step 6, image 1 of 1
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  7. iLive IKBC384S  FM/AM Antenna Replacement: step 7, image 1 of 2 iLive IKBC384S  FM/AM Antenna Replacement: step 7, image 2 of 2
    • Desolder the antenna at the contact point.
    • Check out this awesome guide for soldering and desoldering tips.
  8. iLive IKBC384S  FM/AM Antenna Replacement: step 8, image 1 of 2 iLive IKBC384S  FM/AM Antenna Replacement: step 8, image 2 of 2
    • Place iOpener on antenna for approximately 5 minutes
  9. iLive IKBC384S  FM/AM Antenna Replacement: step 9, image 1 of 1
    • Lift up and remove all of the antenna.
    • The antenna will be glued down all the way around the radio
Tracy Walts
201 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 709
