iLive IKBC384S Disk Drive Replacement
  1. iLive IKBC384S Disk Drive Replacement, Top Cover: step 1, image 1 of 2 iLive IKBC384S Disk Drive Replacement, Top Cover: step 1, image 2 of 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Disk Drive Replacement: step 2, image 1 of 2 iLive IKBC384S Disk Drive Replacement: step 2, image 2 of 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Disk Drive Replacement: step 3, image 1 of 2 iLive IKBC384S Disk Drive Replacement: step 3, image 2 of 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Disk Drive Replacement, Disk Drive: step 4, image 1 of 2 iLive IKBC384S Disk Drive Replacement, Disk Drive: step 4, image 2 of 2
    • Remove all four screws(13.5 mm in length) that are securing the device
  5. iLive IKBC384S Disk Drive Replacement: step 5, image 1 of 2 iLive IKBC384S Disk Drive Replacement: step 5, image 2 of 2
    • Remove both of the connected cords on the motherboard.
    • Also remove the flat ribbon cable that is connected to the motherboard.
    • Once you have removed all screws and cables connected to motherboard the disk drive can be easily removed
Allen Dover
401 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 431
