iMac 27" Mid-2011 Broken Display Power Connector Pins Replacement
  1. iMac 27" Mid-2011 Broken Display Power Connector Pins Replacement, Locate broken pin: step 1, image 1 of 2 iMac 27" Mid-2011 Broken Display Power Connector Pins Replacement, Locate broken pin: step 1, image 2 of 2
    • This can be a connector within the iMac or another board for parts. I found an unused connector in my computer.
  2. Tool used on this step:
    Buy
    • Apply the soldering iron to the base of the broken pin connected to the circuit board while levering the tweezers behind it pulling it out slowly.
    • Same as previous step.
    • Slide the pin in the desired connector until it is firmly seated inside.
    • Apply pressure to the base of the pin with the tweezers and solder the pin back in place.
Finish Line
Mathew Mulligan
143 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 34
All Time: 5,709
