iMac G4 15" 700 MHz EMC 1873 Optical Drive Replacement
Introduction
Go to step 1Replace the optical drive in your iMac G4 15".
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
Using a Torx #9 screw driver, remove the two 8.77mm screws holding the drive's shield onto your iMac G4.
Remove the drive shield from your iMac.
16 other people completed this guide.
